RAM 3500 Limited LED Headlight Question (Steering Directed Headlights)
wifi_guy
Northfield, MN
6.7 I6 Cummins HO Turbo Diesel
So, I haven't really seen this posted anywhere and I am more or less curious. So the RAM LED headlights rotate when turning. If you swapped out your headlights to something 3rd party, do you loose that feature? Or is the entire housing that the lights mount into move?
I have seen guys online doing this that have the Steering Directed Headlights and have wondered if they are loosing that feature when they swap them.
Thanks in advance!
OC455
Central NY
Yes, you loose that feature. The projectors inside of the headlight pivot. The projectors move 30 degrees side to side. The housing stays put. If you are talking about the Morimoto XB headlights for the HD trucks, they do not have that feature.
My questions is, why would anyone be replacing these.....the OEM LED projectors for the HD Longhorn/Limited are awesome headlights.
VA-RAM
STL, MO - Norfolk, VA
2017 Laramie / 2020 Laramie
So... reading this just piqued my curiosity. Will the 2500 Laramie headlights fit in a Laramie 1500 of the same year? Curious if you can retrofit the "pivoting projectors" in a 1500 with projectors...? AlphaOBD settings? Harnesses or re-pin connectors?
OC455
Central NY
The HD headlights are completely different than the 1500 headlights.
Ram 1500 headlight halogen Tradesman/Bighorn:
Ram 1500 headlight LED Laramie/Bighorn:
Ram 1500 headlight Limited LED Projector:
I think that it was mentioned the Limited/Longhorn do pivot like the HD truck headlights:
Ram 2500/3500 headlight halogen Tradesman/Bighorn:
Ram 2500/3500 headlight LED Bighorn/Laramie:
Ram 2500/3500 HD headlight LED Projector Limited/Longhorn:
