You could build your own with some 2x6’s or 2x8’s.
RhinoGear 11912ABMI RhinoRamps MAX Vehicle Ramp - Pair (16,000lb. GVW Capacity) https://www.amazon.com/dp/B0117EESNC/ref=cm_sw_r_cp_api_fabt1_A0ESFbAZYQC0D?_encoding=UTF8&psc=1
Something like these?
I quit using ramps or a jack under my 1500. Or a creeper.
I found it easier to slide under on a glossy piece of cardboard. It’s tight but easily manageable for an oil change. I am fairly lean at 6’2” 200lbs though.
the reviews on these are mixed and it’s not entirely clear what the weight capacity is but it appears to definitely not be 16k. I have a 3500 so I’d like to be certain.
This is why I posted here, I’m looking for first-hand experience.
This is what I've been using for over 10 years. Gives me enough clearance under my truck to use a 5 gallon bucket to catch the oil in. Which was needed with my 07 Cummins.The black fiberglass ones from Harbor Freight Tools have the weight capacity your looking for. They're very solid and light weight too
Black 20 Ram
