Random rant- 2500 greasing front driveshaft
smurfs_of_war
Swift Current, Saskatchewan
The engineer that thought that was a good idea should be shot and pissed on. Seriously. Sometimes I think they get paid to sit around a table to devise the most screwed up, infuriating ways of complicating simple routine maintenance. Masochists.
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Yeah it is a ***** to do even with the right adapter for the grease gun. Did mine last week for the third time and if you do not hold that needle adapter just right, grease goes everywhere but in the fitting.
MANual_puller
Shade tree grease monkey
Vinton, Iowa
2011 Moose
5.7L hemi
Definitely not something you want to do without putting cardboard down first lol
smurfs_of_war
smurfs_of_war
Yup. Thinking there might be a little slinging grease for a bit.
Alarmingly when I went to grab the "official mopar grease" they didn't have it. Never have had it. They only grease them when the customer asks, and use plain old bearing grease (which is perfectly fine except for the "must meet or exceed blah blah blah spec) So I grabbed some Lucas heavy duty and called it good- it was on sale ;)
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
god invented the battery powered grease gun just for these pita jobs.i cut my grease time for my tractor in half with one.worth every penny.get the fitting just right and pull the trigger.
smurfs_of_war
smurfs_of_war
Yeah we use them on our equipment too and I have resigned myself to the fact that I have to buy one for home now. I am not nearly as annoyed by that as my wife is lol!
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
Alarmingly when I went to grab the "official mopar grease" they didn't have it. Never have had it. They only grease them when the customer asks, and use plain old bearing grease (which is perfectly fine except for the "must meet or exceed blah blah blah spec) So I grabbed some Lucas heavy duty and called it good.
I think so long as the grease is lithium based, you should be alright. Most general purpose or multi-duty type greases are lithium based.
smurfs_of_war
smurfs_of_war
Its polyurea shear stable. So it *should* be compatible with lithium greases. I was tempted to try and purge some out of the joint until I realized after about 4 pumps that it was basically empty. I will just lube it a little more frequently for the first little while to make sure it has no more lithium grease left in it.
