Rapid Turn Signal
waffleman10
Connecticut
I recently installed a new pigtail connector for my headlight on the driver side because the old one was corroded. I just used some butt connectors to connect the 3 wires and it was succesful. I then was testing everything and for some reason the left turn signal now flashes rapidly and the rear left turn signal works and the front (where i just replaced the headlight) dosent work. Here is the thing, the bulb works if i turn on the parking lamps, its just the blinking function is gone and the back blinks rapidly. I didnt accidently cut any wires to the front blinker by accident. Anyone know what this could be?
mrfyram1500
2024 1500 Laramie
Ohio
Swap with the bulb on the other side to see if the bulb is bad. Or just put in new. Maybe vibration from moving things around broke just the turn signal filament. The rapid flash usually happens when a bulb is out.
mrfyram1500
2024 1500 Laramie
Ohio
Not related to the turn signal, but did you seal the butt connectors with some heat shrink tube?
waffleman10
waffleman10
Connecticut
yes they were the heat shrink butt connectors, i used a lighter to heat shrink them, not a great idea, but it worked
mrfyram1500
2024 1500 Laramie
Ohio
A heat gun would do it too (or maybe even a hair dryer)
waffleman10
waffleman10
Connecticut
yeah i know but i didnt want to buy a heat gun or even one of those butane torchs, i just went with the $2 lighter
