imtonydillard
My issue is my truck is 9 times out of 10 when I come to a stop. Sometimes I can get it to start immediately. Most of the time it take 5+ minutes and smells like it's flooded. BTW, this mostly happens when my truck is near empty. Not so likely to happen when i have a 1/2 tank or more of gas. Also, I parked uphill the other day and had a real hard time starting it. I put it in neutral and rolled it to as close as possible to level ground and got it to start. There's also been times when it stalled before I came to a full stop and I tried to roll start and no go.
My vac lines are all good. My throttle body has been rebuilt and I also have a new EGR valve.
Most of my research points to the fuel pump as the culprit. What are your thoughts? I went ahead and bought a new fuel pump but can find where the existing one is to replace it. HEEELLLPPP please. My Haynes manual is failing me.
