Re-use AMP PowerSteps?
maxsteel
The PNW
CTD
I'm considering trading my 2015 2500 up to a 2018 3500. I was curious about my AMP PowerSteps; is it possible to remove them and re-mount on the new truck? Or would I be better off just buying new ones?
Jimmy07
Remove them, cuz they ain’t gonna give you any more money on your trade if you leave them on.
Razzman
Southern Arizona
2020 Limited CCSB
Don't see why not. Assuming nothing changed on the 2018, you'd have to get more rivnuts for the install. The one issue you might have is the harness, is yours the plug-n-play where it connects to the OBD port or is it tied into the truck wiring? If it's the truck wiring you might want to get a new harness with the plug-n-play, much easier to install.
WilliamS
Tampa FL
You just need to buy new rivetnuts for the new truck.
MADDOG
Living in a Firepit
6.4L HEMI
New rivnuts will be needed. I'd check their website to see if the same part number fits the new truck that's on your current truck.
Wahrsuul
Central S.C.
Are the mounts the same between a 2500 and 3500? If so, take those with you.
oe542bob
Hemi eTorque 5.7
If you had plug & play obd, it will not work on the 18s. Something is different. So, they would need to be hard wired. Amp Research was working on the ‘18 model. I haven’t checked for a while, but I’d think by now they would have it working.
So the steps you have now are just for ‘17 and older. Check with Amp Research.
M
maxsteel
The PNW
CTD
Good to know, I'm actually debating between a used '17 with 5k miles and a new '18, pretty much identical. As much as I want the CarPlay in the '18, I just think the crosshair grill looks so much better. This would be one other benefit if my steps work on it. I will follow up with Amp.
Ramaniac
Western WA
2017 1500, Laramie
3.0 Ecodiesel
I really wish I would have done that. They don't give those things away and my wife insisted I put them on my new truck.
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
Thats not true at all, i just put some on a 2018 2500 no less than a month ago, the OB2 PnP ones work amazing on these trucks
You will definitely need to get more of their riv-nuts for the job, but you bet your ass id take em off lol
