Really annoyed
RangerWeaver
York, Pennsylvania
V8 4.7L
Now this is the third time that this has happened. Earlier today when i was pulling into a parking spot the motor just died. I cant start it with my foot on the break but if i start it with some gas there is no problem. The first time it happened i was driving in heavy traffic then it happened again when i was goi g down hill towards an inner section.
could it be the fuel injectors like i think it is or something else?
rowdyram
magnum 5.9
IAC is my first thought
rowdyram
magnum 5.9
Try removing it cleaning reinstall. Disconnect battery for 10 min. Then try it out
ADudeOnSkis
Truckee, CA
318/5.2 Magnum
Does your fuel gauge work?
While you're in there cleaning the IAC check fuel pressure at the rail.
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Yeah when I put my engine in I had to press the gas to get it to start and it wouldn't idle. Forgot to plug in my IAC. I think yours is likely on its way out.
