Just started about a week ago. I hear it in the cab at low & mid speeds mostly. Still under extended warranty. Best to see if they will change out the fluid or are the rear gears headed south? It's a 2016 with 3.92 LSD and a 5.7 Hemi 8 speed.
I do tow about twice a month but usually around 4500 lbs or so on a 1200 lb. trailer. My rating is 10k for towing.Put some cheese in there, I hear wine and cheese is a good combo, ha.
If you are under warranty you still are responsible for maintenance. I'd pop the cap make sure no gear tooth damage and take note of how many shavings are on the magnet. Need gasket maker for the install, I think it is under 3 quarts for a fill. If you see an issue I might just put Mopar fluid back.
More of an issue in cold places, do you tow heavy?
What was it?I had a whine at 80k around 90k it got really bad. Fixed under warranty.
A transmission mechanic says he fixes these all the time. Apparently its common
Sent from my moto g power using Tapatalk
It just started so haven't towed since the noise showed up. Will know more next week when I have a 4k load in back.Do you notice it makes more noise under load? like in a high gear gently pressing the gas enough so it doesn't up shift? then quiet when coasting/not under load. My pinion bearings always make a little noise 200k+ never a issue But if your under warranty def take it in.
