Rear bench to 60/40 split bench seat mod
Mike Firman
5.7L
I looked but couldn't find the answer in the forums. I purchased a 2017 Ram 2500 Crew Cab Tradesman with the full rear bench seat. I found a great deal on a 60/40 split rear bench seat. I didn't realize they came out of a quad cab though. I went to install and realized the seat brackets aren't the same. I have the two brackets from the existing bench I can use. My question is, does anyone know if the brackets I have can be used with the split bench seat? I will need to purchase at least two brackets I just want to check to see if I will need all 4 brackets or not. The parts diagram I found for both seats has different part numbers for all 6 brackets between the two types of seats.
SitKneelBend
St. Louis
3.6 Pentastar
If I'm not mistaken I remember someone going the other way so my answer is maybe...try searching the forum for "crew cab seats in quad cab"... He was succesful if memory serves.
