Cliff R
- Mar 25, 2018
- 6
- 0
- Location
- Mount Vernon, Ohio
- 2017
- Hemi 5.7
Hate to be a "newby" and log on with a gripe, but I'm having a problem with my 2017 2500 5.7 Hemi Powered Ram truck.
The rear differential has developed a "whine" and it's getting worse. It only occurs at very light load, and shuts up immediately if you coast or apply load.
The noise doesn't start till about 55mph and is most pronounced between about 62-68mph. It's loud enough that you can hear it above the radio at moderate volume.
It's been to the dealership twice to correct the issue. First time they did nothing more than drive it and tell me that it's not making any noise that anyone can hear.
Before taking it back the second time I checked the oil level and it was way below the fill hole, far enough I couldn't reach it with my little finger so I added a quart of gear oil. Still couldn't touch the oil so added another and it came up to about 1/2" blow the fill hole. About half way thru the 3rd quart it started to run out the fill hole so I stopped filling it.
Now I'm smart enough to know that it's got a little too much oil in it at this point, but I wanted to drive the truck knowing it had PLENTY of oil in it to see if the noise went away, which it did not.
So back to the dealer it goes and once again they said there is no noise they can detect and it was over-filled with oil. Yes, I told them I did that because it was pretty low on oil and I wanted to try and shut the differential up but filling it to the level of the tread for the fill plug made no difference.
The dealership went ahead and removed the cover, took pics of the internals, filled it with new Mopar oil, and gave it back to me.
That was about 2 weeks ago and it's still whining just as bad if not a tad worse.
Anyone else have one of these trucks whining at light load on the highway? If so what did you or the dealership do about it?....tks in advance......Cliff
