Rear Fuel Filter Wrench Question
jdrowe50
Longview, TX
Hello all.
I just changed my rear fuel filter for the 2nd time. I had to use a massive set of channel locks. The first time I used a filter wrench that was a little small but it worked. This time I couldn't get it to grab. My question: Is there a great tool for removing this rear filter? I have the correct socket for the filter under the hood, the wrench for the rear sensor, the correct oil filter wrench, and even the oil filter plug so I can prevent spillage.
Just need help with ideas for the rear fuel filter. Thanks.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
You're clearly over tightening it if you can't get it with a standard filter wrench. It doesn't have to be that tight.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
WY-Dave
Cheyenne, WY
6.7 CTD
He has the sensor wrench. His trouble is getting the filter to loosen. Sounds to me if he can't get it with a standard filter wrench it is being overtightened initially.
Damn I need to read better. I have one like this that the handle folds. There is not alot of room to swing a handle. I also but in a thin silicone band.
I would love to see if a 5th gen setup could be retrofitted
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Yup, I have the same wrench. I carry it under the back seat with spare filter and sensor wrench. You never know if you're going to get a bad batch of fuel and need to change it on the road.
