Rear power plug replacement
elcid2000
HEMI 5.7
I didn’t find this anywhere, but does anyone know how to replace the 115v plug in the back of the center console in the rear row? I wanted to replace because the cover and bottom plug was broken off. I know it snaps in, but how does it come out to replace? If the cable long enough to pull out and plug in? Thanks in advance!
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I am not suggesting anything about the back side of the floor console
BUT
one thing you should get is a set of TRIM TOOLS, even if they are Harbor Freight brand
Use them for prying, instead of metal screw drivers, etc.
PITTSBURGH AUTOMOTIVE
Nylon Pry Bar Installer Kit, 4 Piece​
ThunderMug95
North Prince George, VA
BUT
These are life savers for trim. I got an Amazonian set and use them all the time. These and the plastic exterior christmas tree screw pullers.
It is most likely in with metal or plastic clips, with some slack in the cord. I would DELICATELY pry at it a little…obviously with the power to it interupted!
E
elcid2000
HEMI 5.7
Yeah, plan on getting some tools since I’ve never bought them. Fuse enough t cut power? I’d hate to have to figure the radio situation if it has a code to deactivate.
