Rear power slider
Kilroy2981
New york
5.9 cummins
Hey guys, I have a question about my 06 3500. I just converted from a manual to a power sliding rear window. The window came with a motor that has 2 pins on it. I took the C pillers out and there isnt any wiring there. If the harness was there, where would dodge have ran it? Also, I ordered the switch that fits in the radio bezel. When I take the bezel off, there are a few connectors that are attached to the plastic under the radio. One of them is a black 8 pin connector, is that for the power slider? I ordered the switch but I didnt get it yet. If that isnt the correct connector, how would I go about wiring the switch to the window? Sorry for the long post and any info given will be appreciated. Thanks guys
bellaireroad
Fort Worth
I did this mod.... here is a link showing the wiring I did. Unfortunately I did not have the connector that plugs into the switch. They are hard to find. I had to buy a headliner harness on eBay, others that have done this have found them in junkyards. The motor connector can be ordered from Mopar
Ricks Ram walked me through it, he is very helpful!
https://www.ramforum.com/threads/electrical-rear-window-upgrade.147520/
apriliaalex
NH
Does this conversion let less water in the weather seals?
Ricks Ram
Not exactly sure what your question is. As far as the outside perimeter of the window is concerned it's got a rubber seal just like the regular rear window. Both windows are installed with a urethane bead and if installed correctly won't leak. As far as the power sliding part of the window is concerned it's got a rubber seal against the glass. I installed the factory mopar power slider. I've had installed for around four years and it's never leaked.
stevenmicheal
