Rear seat conversion
bryanmeeks84
I currently have a 2500 crew long bed tradesman and have a solid rear bench seat. I would love to put a split bench in the rear if possible. What trim levels come with that and will it mount right up?
Sent from my LM-V405 using Tapatalk
Shawn1986
DFW
I'm sure that solid bench has the same mounting as a split, should be 8 bolts.
Sent from my LG-LS993 using Tapatalk
Elevated 2013
Huntley, IL
The Sport model has the split bench but I’m not sure if the mounting bolt pattern is the same. It would make sense for them to be the same though.
Dave2018
2018,Previous 1998
3.6L,Previous 5.9L
the floorpan is stamped for split bench mounting. the carpet is too. ive never pulled it up to see if the bolts are there.
B
bryanmeeks84
Would all gen 4 models be the same back seats? Trying to see what years I can ask the junk yard for seats
Spydieee
Kingwood (Houston) Texas
Bump for update.
I want to either swap to a split rear seat from 1500 tradesman or to a single rear racing bucket seat for my son. I don't use the back seat for anything but him riding back there and to store power tools.
Joshua Collins
2011 & 2023
6.7 & 5.7
Just need the 4 additional bolts for the seat install as far as i can tell. Pull the current back seat 4 bolts and make sure the holes are not filled where the 4 additional bots are going to go with the split bench. If they are there and not filled will be an easy swap just make sure to torque the bolts back up.
novelmike
Central California
What is the difference between the quad cab and crew cab rear seats and the mounting holes?
Are they the same??
I see a lot more crew cab seats for sale than quad cab.
