Rear seat folding load floor
emski
san angelo, tx
6.4L Hemi
I recently purchased a 2021 Ram 2500 Tradesman with a one piece rear bench seat. I would like to install Mopar's folding under seat load floor, but the only one made is for the 60/40 split rear seat. The two part numbers are, 6YA06TX7AA (60%) and 6YA07TX7AA (40%). No help from dealership and could not find any info on line. Will these two part numbers work on this vehicle, or can they be modified to work. The truck vin number is 3C6UR5HJ4MG681550. Thanks for any info that is available.
NH RAM
New Hampshire
2019 Tradesman 2500 Snow Chief
It's a two-piece folding floor so you need attachment points for the 60/40- I don't know if that can be accomplished with the bench seat. I've been looking to find reasonably priced Big Horn premium seats to accomplish this and to have the center armrest on the back seat. It seems that used parts sources don't like to respond to email inquiries as I've sent a couple out so far on full sets of Big Horn seats with no reply (I'm usually looking well after business hours are over).
Ram Dog
Nordland, WA
Cummins
I have a 2019 Tradesman 35000 with the single bench and would like to make to add this platform. Is there anyone who has a factory 60/40 split and platform that can share some pics? I was wondering if I could just fab a third anchor point or if I really need a new seat setup.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I see you have a HEAVY DUTY RAM
all HD Rams are 4th Generation, built in Saltillo Mexico.
Ram 1500, 1/2 tons built at the Warren Michigan Assembly Plant, are also 4th Generation Rams
That means that you can look for any 2009 - 2018 Rams that might have the split rear seat
2019 - 2022 Rams that are referred to as Ram Classics, look at the door sticker to see if it was built in Warren Michigan if it is a 1/2 ton 1500
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
ooooooo ahhhhhh, you have fancy shmancy carpet on your load floor. I want that.
Was that an option or did you make that?
GTyankee
3.0 ecodiesel
It is all factory
the 2009 Dodge Ram 1500 SLT & the 2016 Ram 1500 Bighorn, had the exact same setup
Ram Dog
Nordland, WA
Cummins
Thanks @GTyankee, just what I needed. The outer seat connections are the same as mine. I will order up a factory platform and see if I can fab something for the center if I dont find a 60/40 seat to swap
TheNinja
Boise
6.4l Hemi
@Ram Dog, assuming you get this to work, please share back what you ordered and advice on how to retrofit to work. I have a 2022 2500 6.4L Big Horn with a single back seat and would love to find a way to add a folding floor.
gofishn
Iowa
hemi 5.7L, 345 cu in
Dont go buying the parts new from a mopar store, keep checking the for sale section. lotsof guys get rid o theri fold flat floors to instal bigger sub woofers. How i got mine for my 2014 Ram.
Link above has pcitrees and detailed info on how ot install the floor. 60/40 fold flat floor will work underneath a solid bench seat.
Just got to lift both seats., Can only put down on side of the floor, is y ouwish.
