Meatman8769
Ya the warlock comes with a 1" in rear. I've put the same in the front to level it out. It says on the Fox site they fit just need the proper adjustmentsI think it would be Fox part number 985-24-032 for stock height rear, I'd confirm with @Nick@GotExhaust above since I'm not sure if the Warlock has longer rear springs to match the slight lift in the front.
Also, I do recommend the Thuren shock nut kit, it'll cut down the install and then later on reinstall time significantly.
