Rear suspension and lift
Yeti801
Utah
Okay, I have a 13 ram 1500 I know the truck did come with a small lift, pucks all the way around from factory. They also put 2500 coils and airbags in the rear to make it a heavy half. So the question is, I like the rear set up because it pulls really nice, but I would like to add a better suspension lift. What I don't want to do is affect the rear suspension and how they have it set up. Can I just add new shocks to the rear to go along with a new set up in the front? Or is it better to stick with the same lift and ne parts all the way around?
crazykid1994
You can buy a lift that supplies rear spacers instead of new springs. And doubtful they are ram 2500 coils. More than likely they are just heavy load coils like tuftruck coils. What size lift are you looking for
Yeti801
Yeti801
Utah
I found the build sheet and says 2500 coils with rear spacers. I'm not looking for massive something like the icon, Carli, ect. 3 to 4 inch. Which will benefit front by an inch or so.
Yeti801
Yeti801
Utah
It's already lifted, well from is leveled and rear is still a little higher. Either way it got the lift from factory.
crazykid1994
Interesting. Are you the original owner? That’s the first I’ve ever heard of a truck with 2500 coils and airbags. Are they inside the coil airbags or frame mounted airbags where the bump stops usually go. I would be looking at a zone 4” kit if that’s really all you want. They come with 2” rear spacers which would leave your rear springs. And the factory lift is a bilstein leveling struts lift usually or a superlifts lift kit rebranded. @Quick_Shifter ever heard of that?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Lets see pictures
Yeti801
Yeti801
Utah
I am not the original owner. That's just what my build sheet says. And yes they are in the springs. I think bit not 100 percent sure but I think they're the airlift 1000s.
Yeti801
Yeti801
Utah
Here's the rear.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Strut 1.JPG Something like this
Yeti801
Yeti801
Utah
Okay here's some of the rear. It's dark so sorry snot that.
Yeti801
Yeti801
Utah
I will have to crawl under the front tomorrow.
Yeti801
Yeti801
Utah
Also sorry it's so messy, the place I got it from got undercoating all over everything.
Yeti801
Yeti801
Utah
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
What suspension are you running?
Glad you asked
CB68A457-6BCB-459A-88D9-BC1CD08795E5.jpegC1DEC9F9-F9AF-4C6D-8CC4-CE3B39B5114F.jpeg7AC987FE-6153-4C72-8A6F-D855B39AD826.jpegD1FBAD18-7547-4D46-B845-EA9B6FA11749.jpeg
I’m on a Zone 6” lift fox 2.5 full length coil over in the front no spacers and 5” rear full length springs. Core 4x4 control arms, panhard and endlinks holding the hellwig swaybar
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Those are 1500 springs with the helper airbags and bottom coil spacers. Are you looking it add more height? Or do you want to stay where you are
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
@Yeti801 you have tail lights from a 2500 5th gen maybe that is where the confusion was
