Bigdog9598
- Nov 22, 2016
- 23
- 1
- Location
- Florida
- 2007 - 4x2 - SLT
- 4.7 flex
hi all, not sure if this is the right place to post my question?
any thoughts are greatly appreciated.
Rear tires, sever wear right rear outer edge of the tire, outer edge has worn down almost level with tread indicator.
left rear is starting to wear, but not as bad as the right side.
thoughts on whats causing this?
tires were new and balanced in October 2017, replace rear shocks November 2017. had alignment front to rear checked.
no grinding noise coming from the rear. leaf springs appear solid, no signs of movement. Bushings do not appear to be sized.
all rear suspension is factory except the shocks. 181,900 on the clock.
thanks Tom
thanks Tom
