Rear window slider leak
RamRBest
Kentucky
5.7 Hemi 1500 Laramie Longhorn
My 2015 is leaking water around the slider rear window. I can’t find a drain hole in the cable channel and water runs to the ends and down to carpet. I don’t think new seals will stop the water from getting in. Any help in a fix is appreciated. Are the seals easy to install?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Rear sliding windows on your Ram have two drains
the exit end of the holes are in the bottom of the window seal, on the side against the sheet metal
I'll look to see if i can find the video on how to clear the tubes
Generation3 Dodge Ram slider window drains
https://www.youtube.com/watch?v=vaLorjtb7e8
so far nothing on the 4th Gen Rams
R
RamRBest
Kentucky
It is a 2015 model. I have three drain holes visible but can’t find how the water from the slide gets to those holes. Also if the truck leans slightlly to the driver side the water ends up at the end and runs out the end.
GTyankee
3.0 ecodiesel
