Rearend movement on/off gas
Lifted2wd
Getting a weird side to side movement when accelerating and then letting off the gas.
On acceleration it feels like I'm shifting to the passenger side, then corrects its self when I'm off the gas.
I checked the links in the rear nothing broken. Next is going to be replacing the rear control arms so that I have all new bushings.
200k miles 4" front lift, 1.5" rear spacers
37x12.50 tires
Any thoughts?
MAC830203
Beaufort, SC
Magnum 408
That’s scary. If you lift you gotta use Teflon Bushings. Everything bigger gets exaggerated. Ram1500 is spot on.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
37x12.50 tires
Any thoughts?
@Nick@GotExhaust can set you up with a set or rear control arms.
Nick@GotExhaust
Preferred Vendor
SC
I agree, sounds like rear control arms are shot. I would upgrade to something stronger especially if you off road. Core 4x4 is the answer. Let us know if you would like a quote. just send me a message if interested.
Brian2081
Weatland Michigan
You might want to check panhard bar and its attaching points, since that is what controls side to side movement / keeps the axle centered.
