Dr. Righteous
- May 13, 2016
- 432
- 467
- Location
- Jamestown TN
- 2014
- 5.7 hemi
There are a lot of YouTube videos on this technique and I've probably watched all of them.
There are different opinions on the "best way" do so this but most are cycle the charge/rest time in 5 min charge and 10 minutes rest. Do at least 4 or 5 cycles and then tech the battery with a load tester.
I have a DC arch welder that can crank out 160 amps if needed. It will run on 110v or 220v but I'm using it on 110v.
So far I've tried 2 different batteries and so far 2 failures.
I know this technique isn't guaranteed to work every time but the batteries do go from dead, totally flat; Won't accept any kind of charge from a regular battery charger to holding a 12V+ static charge. But when you putting a load tester on (typical 100 amp tester) the batteries will drop to 8v and just won't deliver much current. Sticking on in a car will you 1 revolution, and then nothing but clicks.
I start by cleaning the batteries up, scrubbing the gunk off the top and cleaning the terminals with a wire brush. I pull the caps and check the electrolyte level and top it off with distilled water as needed. Load testing give my just a few volts and no capacity to deliver any current.
I'll set the welder to deliver 20-30 amps to start and then look for bubbling action from the cells. Typical I'll have more action in some sells than other but all cells will will bubble.
I've tried different amounts of current and different on/off times with the same results.
I've NOT put more than about 70 amps into a cycle even though you see a big increase in bubbling action. I try to stay in the 20-60 amps max. Both these batteries preformed well last year and took a good charge with a cheap 10a charger and stayed strong with long cranking attempts. So I really don't think they are beyond all help. I'm just wondering what else I can do that might bring them back to life.
