Relays
chicaria
illinois
I'm trying to narrow down an issue I have with my wipers. Anyone know if the 2006 Ram 1500 has a relay for the wiper motor?
I dont see any in the TIPM and nothing under the dash that resembles the ones that the parts stores advertise as a fit for my 2006 Ram 1500...see below.
The wipers are getting power from somewhere, I just dont know what that somewhere is.
I'll be looking at the multifunction switch on the steering column next once the relay mystery is solved.
Smokeybear01
Army
US-NW Coast
Cummins 5.9
My wipers developed a mind of their own a couple years back. I would hit the remote lock and the wipers would go. I'd turn off the headlights and the wipers would go. When I put them on intermittent they would stop and start on their terms unless I put them on full speed. It turned out the contacts on the back of the wiper motor corroded and they were getting mixed signals. I tore it apart and sanded down the contacts and they've worked flawlessly ever since. Since I forgot to use dialectric grease on the contacts I'm expecting them to act up again in the near future. This is a common problem so it was easy to find a utube video to walk you through it, if that is what you're experiencing. Good luck
C
chicaria
illinois
Yeah, thats probably the issue but, I'm still curious as to where the wiper motor gets it's power from.
Smokeybear01
Army
US-NW Coast
Cummins 5.9
I'm showing 2 relays in the IPM. One is for wiper on/off and the other is high/low relay. After digging a little deeper, it looks like it's fuse #8 (30Amp). Controls a bunch of other stuff related to the washers, fluid level sensor, etc. HTH
stevenmicheal
