Relocation brackets for 1/3 Drop? Stock length shocks?
moto-m
USA
5.7L
I tried to look for the information and search here. Does a 1/3 drop only require springs? No relocation brackets? Stock length shocks ok?
Thanks for the help.
M
moto-m
USA
5.7L
Thanks so much for the overwhelming amount of replies and helpful tips! Seriously slow down, I cannot keep up.
M
moto-m
USA
5.7L
But seriously, will the KYB MonoMax shocks (stock application) work with a 1/3 drop?
abouttobeglue
I used kyb monomax 565038 and 565127 for a 2/4 belltech drop. One is a stock length that will for the front, the other is a little shorter to work with the rear drop. Fyi when you install the rears install the top bolt before cutting the strap, otherwise you'll be using a floor jack to compress the shock.
abouttobeglue
Don't know on brackets, I had to have em on mine for the wobble, you may bot need them, it varies truck to truck it seems.
abouttobeglue
If you do an adjustable panhard bar spend the extra money on the core 4x4 street version. Much beefier than the spohn i had on and no flex at the adjustment point
M
moto-m
USA
5.7L
Thank you. How did you like the ride? I would prefer a stiffer, sportier ride.
M
moto-m
USA
5.7L
I may just do a 2" rear drop for now and see how I like it. I still use the truck for hauling supplies and towing a boat.
abouttobeglue
I liked em, took em off to try the belltech nitro drop, which are too bouncy, got a set of kyb gas ajust coming today.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Ground Force makes a 2" drop, simple 30-40 minute install.
Here is my 2011 with just a 2" rear drop
M
moto-m
USA
5.7L
That looks good. I can still use the Air Ride kit with the rear drop, correct?
abouttobeglue
The monomax rode really well, much firmer/more controlled than stock or belltech. I'd put em on a stock truck, I was impressed.
M
moto-m
USA
5.7L
That's what I wanted to hear. Now if I only do the 2" drop, go with stock length monomax or the shorter rear shocks?
M
moto-m
USA
5.7L
I'm going with a 2" rear drop. KYB recommended the 565103 for the rear shocks.
M
moto-m
USA
5.7L
Finally got the drop coils and new shocks installed today. Took a chance on some Touring Tech 2" rear drop coils from eBay for $104 shipped. Seller said they are about 20% stiffer than stock. Went with the KYB MonoMax shocks on front and rear.
Only been one day but extremely happy with the stance and ride so far. Shocks made a significant difference. Feels almost like a sports car now, which is what I wanted.
In case anyone needs the info (which has probably been posted here somewhere already), front shocks are part# 565127, rear are 565103 (KYB said to go with these for only a 2" rear drop, said to use 565038 for a 3" drop).
VLG6963
