Remote oil filter how-to
daveray9
How much extra oil do you need with the kit?
Villalobos
USA
5.7l hemi
After install it was a quart low. Next oil change I’m planning on 8 quarts.
tantore
texas
hi guys where did you get the adapters for the 10an to the 3/4 npt thread to the remote filter mount kit and if you have stock no. will be great i will be using bthe stock hose that came with the kit thank you all in advance
Fiddlebick
Utica ky
I originally posted last spring about the transadapt kit leaking from I blown out pin hole in the casting, and they sent me another right away which took care of the problem. I used cheap ebay 10 AN fittings which worked well for awhile, but late this summer I've developed a small leak that I can see on the garage floor...a drip, maybe a half a teaspoon after I shut the truck off and it sits for awhile cooling down. When I inspected I couldn't tell exactly where the leak is, just generally wet, you know the way a leak will blow around and spread from the wind at road speed. Most likely the fitting? Anybody else had an issue with their fittings?
Villalobos
USA
5.7l hemi
I installed on October 11 2020, so just over a month. Just used what came with the transdapt kit. Only mod was some hose clamps. So far so good, no oil loss. Not a lot of time on it yet so take my anecdotal evidence fwiw.
tantore
texas
hi guys any one that install the filter relocating kit 5 or 6 years ago had any problems with the kits like oil leaks hoses rotting or adapters leaks any problems at all please give some info . thanks to all
chris52010trx4
ontario
Nope been solid since 2015 when I put on my first truck now on my second
Sent from my SM-G965W using Tapatalk
misfit77
i sorta took a cheaper easier route at first and had leaks within months.
So i bought viton oring and proper AN parts. problems gone. Hopefully no issues in the next few years.
daveray9
Share your part list?
I've had both the single and dual kits on my truck,neither have ever leaked,but i upgraded both the hoses and fittings to -10 (5/8") from the -8 (1/2") hoses and fittings they come with.Use good quality hoses and fittings with a smear of pipe thread sealant where the fittings screw into both the filter adapter and remote filter mount and you shouldn't have any leaks
tantore
texas
thank you wild one for your answer and advice
misfit77
Sorry I had to go dig up from an earlier post. I have more detail and photos on this thread post #207/page21
ENGINE SIDE:
Perma-Cool Dual Port Spin-On Oil Filter Adapter 3798
568-912V -12 Boss Viton O-ring
568-230V 2 1/2" Viton O-ring
2x RaceFlux 1/2" Male NPT to -10AN Male Flare Adapter Fitting
2x Redhorse Performance -10 45 Degree AN Push Lock Hose End - Blue
2X Gates 32925 PowerGrip Hose Clamp
REMOTE MOUNT:
Earl's Engine Oil Filter Remote Mount 2577ERL
FRAM PH2/FL-820S to PH8A/XG8A Engine Oil Filter Mount Converter Nipple
2X 2 of Aeroquip FBM1514 Size (10) Straight Socketless Hose End
3 metric screws (size 8 i think)
3 Nord-Lock Washers
HOSE:
Aeroquip FCN1006 AQP Socketless Hose 6 ft. Hose -10AN Hose
DEI Fireshield, leftover from a turbo project.
daveray9
ENGINE SIDE:
REMOTE MOUNT:
3 Nord-Lock Washers
HOSE:
Thanks man!
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
ENGINE SIDE:
REMOTE MOUNT:
3 Nord-Lock Washers
HOSE:
How much was the total for all this ? Just waiting for my redline and fumoto drain valve to show up and would like to add the relocation kit as well ....
Valkyrie0002
Fredericksburg, Va
2017 Big Horn CC
I installed the 1127 kit on my Ram this past Saturday. Fired it up and had oil pouring onto the driveway. There is a hole in the casting of the engine block adapter. I called Hedman and they told me to contact Amazon for a replacement. They would not cover anything for all the lost oil I had to drain down before I could remove the adapter. Not to mention I had to cut the hoses because they would not pull free from the barbed fittings.
Isn't this the second time you've bbitched about the adapter.I'm pretty sure you whined about this a year ago.How many times are you going to repeat this story. I'm pretty sure the last time you posted this,i told you they were mass produced cast aluminium adapters,that they've been making for as long as i can remember,so they're going to have the odd one not up to par. BTW you're the only guy i know who's ever had one leak,think i also told you that once already to. If i was really bored,i'd look up your old post,but i'm not that bored tonight,lol
