remote start horn disable...
vetteyog
Central PA
2012 Ram 1500, without EVIC; is there a way to turn off the horn chirp when activating the factory remote start?
THANKS!
jws123
nj
Only option is in the EVIC and it will dissable the horn when locking.
caulk04
Supporting Vendor
Consult your manual, there's likely a procedure to disable the horn with locking. I bet that does it.
vetteyog
vetteyog
Central PA
I can disable the horn with the door locks, but the remote start still honks.
jws123
nj
If its aftermarket auto start then its a problem with that.
RamDiver
Marlborough, Ontario Canada
2021 DS
Looking at AlfaOBD under the only 2012 option,
"Central Gateway Module (TIPM CGW): MY2006-12 Non-Powernet",
the only horn option is the following;
