Removing the shift motor shaft
Truemagnum15
Washington State
5.9L
We have a 1999 Dodge Ram 1500 360 automatic 4WD. My husband cannot remove the shift motor shaft from the housing in order to remove the broken fork. Any ideas would be appreciated. Thanks
jbmobbs
murfreesboro, tennessee
Will u give more details? What's a shift motor shaft? Never heard that term
Sent from my SM-G900V using Tapatalk
T
Truemagnum15
Washington State
5.9L
In the service manual it is referred to as an axle vacuum shift motor. There is a shaft, behind the shift motor, that goes into a housing that the fork is inside of. He cannot get that shaft out to remove the broken fork.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Follow these instructions, I cant really make it more simple than that.
T
Truemagnum15
Washington State
5.9L
He was following those instructions. After removing the clips, should the shaft in fig 29 just slide out of the housing? If so, something is still holding it in there and he cannot figure it out
dudeman2009
Magnum 360
The the fork is probably stuck on the shaft. If he only wants to save the housing, he can put vise grips on the shaft right next to the fork and use a screwdriver to pry the shaft out of the fork.
Otherwise, heat the fork with a torch and then try again.
