Replace sump filter seal when changing tranny filter?
Fishman1113
So do you guys replace the sump filter seal when you do a filter change? The guy at the dealership didn't say I had to but it comes with all of their sump filters.
Also the directions say not to put it on the neck of the filter and install it that way. The tech told me to use a seal driver. I don't own a set of them and really don't care to buy one just to install one seal. Any thoughts on that or other install options would be great. Thanks!
JasonK94Z
Anderson, SC
Yes you should change it. You don't need a seal driver to install it. Use an appropriate sized socket to knock the seal into place.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
I dident replace mine because I could not get it out the first time I droped the pan, but I just hit 60k so this time I will be sure to replace it.
Fishman1113
Fishman1113
That's what I was planning on doing but wanted others thoughts. Thanks! Confirmation is a good thing!
Fishman1113
Fishman1113
I also was told that a gasket wasn't necessary. That I should just use silicone. Anyone else do that? I bought the filters and they didn't come with a pan gasket.
Fishman1113
Fishman1113
This is what I have to seal it back up
huntergreen
Marine Corps Navy Badge
i think the op is talking about the filter gasket/seal, not the pan seal.
tantore
texas
one way to avoid the fluid mess intall a pan with a drain plug or put an after mkt. drain plug just my 2 cents
R.L.K.
Bristol , Tn.
I changed the sump filter seal , pretty simple imo , just pull straight down on it with a blunt 90° scribe a litle at a time side to side ...it'll pop right out .
Then just place the new seal in its place press it evenly & firmly with fingers Untill it stays in place @ this point size up a socket of the appropriate size install the socket on a 6" long extension , then lightly tap with a small hammer until the seal is evenly seated .
Here's a link to how I did my fluid & filter change . I also replaced the OEM pan with a Mag-Hytec pan with drain plug .
Hope this helps !
http://www.ramforum.com/showthread.php?p=1351576
Sent from my SM-G900V using Tapatalk
Fishman1113
Fishman1113
I was thinking about that. Thanks
