TX-Ghost
I will be replacing my transmission within the next couple of weeks and need to make sure I have everything I’ll need prior to swapping it out. Replacing with the same transmission. It will come with a torque converter with it, is there a better torque converter that anyone works recommend while I’m doing the swap that won’t cost an arm and a leg?
Also, what all do I need to make sure I have on hand when I begin the tear down and install of the replacement transmission?
Tools, equipment, etc?
Won’t have a lift to use so I’ll be sliding up under the truck to do all the work…fortunately I have a lift so it won’t be as bad.. hopefully.
Any tips or advice would be greatly appreciated as well. Thanks in advance y’all!
2016 Ram 1500 5.7 Hemi 4x4
