looks like ya can with MOPAR partsLol, no you cannot. The only fool here is the one in your mirror.
Mopar Auxillary Light Switch Panel
www.ramforumz.com
he did mentioned in that post wiring kit...
from cumminsforum: These trucks don't have a BCM, its basically built into the instrument cluster. If you took it into a shop that does not know can bus systems and have never really worked on these trucks they are probably telling you your BCM is bad and needs replaced, when there is no such thing.
and this: I've come to find out that the TIPM is the BCM
you DO NOT HAVE TO GET ODD BALL AFTERMARKT PARTS TO DO THIS, CAN GET MOPAR DIRECT PARTS TO DO THIS
and those other guys as well are just soo far out in left field? like dont get ya thong all twisted upOMG LOl WRONG AGAIN. your truck most certainly has a BCM. I have made changes to it many times. IT's located on the firewall to the upper left of your brake pedal. TIPM is NOT THE BCM, 2 separate modules
Just stop, you are so far out in left field and have NO IDEA what you are talking about.
AEV makes a version of that panel, not cheap but you get to say you have an AEV part at least.I'm not sure if I find the stock switch panels confusing, but I like that aux switch bay above the radio, particularly with custom rocker caps. I've had similar setups in my Jeeps, always worked out well.
