Replacing / Upgrading the alternator
knightjp
Dubai, United Arab Emirates
I get a weird battery symbol on my dash every morning at the first start. There does not seem to be any hesitation to start, but it is not as quick. Then for the rest of the day, the vehicle starts up normal and the battery symbol is no long there. This is fairly recent. My recently changed the battery so I'm pretty sure that it cannot be that.
According to the mechanic, my alternator is weak and may not be charging the battery in the way that it should. So I may have to replace it. I know I have one of those smart alternators as well.
I am trying to setup a dual battery system similar to the one in the video and a friend said that I should look into upgrading the alternator if I am to do so.
I'm trying to figure out what is the best route right now.
Do I just get a replacement?
Do I upgrade the alternator and if Yes, to what?
Can I use a constant output one and not a smart one? If Yes, will a constant output cause any issues with the rest of the vehicle's electrics?
knightjp
knightjp
Hi there.. sorry to resurrecting an old thread, I didn't see much of a response on this. I really need the advice as I believe my alternator is on the way out and I need to find the best replacement.
I saw an ad on ebay for a high output alternator (about 350A).
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I think the highest you can tune for is 320 looking at settings. Don't know anyone who has swapped one successfully yet. By successful meaning you don't have a 320amp alt turn 180 because it's pcm controlled
danielmid
Southeast WI
2015 Sport 4x4
I would not put an eBay HO alternator on my truck personally, I would go back with Mopar. Then when you do the second battery get a DC/DC charger and let it do the smart charging work.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Don't forget the big 3 upgrade........
