Reverse light alternatives
Ram82808
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
A brilliant one at that! Now we need a write up on the install lest you constantly get asked how to keep them from spinning with the axle...
Reactions: jbr
Ram82808
Just played with the existing holes with some brackets. Ill take pics once it stop raining . They do work well at noght
curtis
Arlington TX
http://www.ramforum.com/f41/i_think_ill_install_my_4_x_6_led_cubes_rear_bumper_today-68552/
52097d1433531520-i_think_ill_install_my_4_x_6_led_cubes_rear_bumper_today-11109556_705323866260485_4163630829556410700_n.jpg
52096d1433531514-i_think_ill_install_my_4_x_6_led_cubes_rear_bumper_today-11391091_705323916260480_2980416339173184900_n.jpg
this is what I want to do on my truck.....Just looks very clean
jabartram
Corpus Christi, Texas
2020 Power Wagon
20.00 pods from amazon
xrsman
Ontario
3.0 Ecodiesel
I just drilled a hole through the hitch and bolted mine on. Connected them both together with solder and heat shrink tubing, then ran them to the passengers side tail light. I tapped into the reverse light wires and they work perfectly!
Sent from my SM-G920W8 using Tapatalk
RamRMK
Vt
Can someone take photos of the wiring to the pods and how you tied in and where to the reverse light wiring?
xrsman
Ontario
3.0 Ecodiesel
I took one of the taillights off and used tap connectors to tap into the positive and negative wires going to the reverse light on the taillight.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
No relay or fuse? I'm interested in doing it this way for ease of install, but I'm wondering if it might not play well with the factory wiring...
xrsman
Ontario
3.0 Ecodiesel
The reverse lights are already fused from the truck, so I didn't put one on for the pods. I didn't run a relay either because of the low power draw of the LED. So far no issues, they work great!
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
So you wired the two lights together then ran them to a single tail light right? I'm wondering if there would be any benefit to wiring each one individually to a tail light. Any thoughts?
xrsman
Ontario
3.0 Ecodiesel
Well I just didn't want to splice into both tail lights, that's why I did it onto one. There probably wouldn't be any harm in it though
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
True enough, I'm just wondering if there would be a load benefit. Electrical wiring isn't my strong suit. Your setup is nice and easy. I'd think wiring them into the trailer hitch wiring would be even easier.
Does anyone know the wires to tap in the trailer harness?
Rlaf75
Rlaf75
East Hartford CT
2021 Bighorn
The only thing you'd need to worry about by splicing both lights into on side is the draw on that particular wire or harness. LED lights don't draw nearly as much as incandescent lights so I highly doubt there will be any problem. And as long as you splice properly then you won't have to worry about corroding wires
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I also already replaced the reverse lights with LEDs so more room for electrical load on those particular wires (I think that's how it works)...
Rzrman328
The treeline
?..... I'd think wiring them into the trailer hitch wiring would be even easier.
It is in my opinion. That's the route I went.
White/orange....or it's the center if I recall.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Thanks! So that wire is the reverse light power/trigger?
Rlaf75
Rlaf75
East Hartford CT
2021 Bighorn
For the most part yes but I wouldn't run 12 lights off of a 16 gauge wire though. And don't for get, the reverse lights are only on for a minute or two not for hours on end
