Ride issue
pghguy1989
Greensburg, PA
Hey! New to the forums and 1st time Ram owner. Just picked up from a local Ram dealer a 2017 1500 Sport Night with the air ride. 59k miles and everything works as it should.
Had it out for it’s first highway drive and between 60 and 70 notice a light vibration in the steering wheel and in the seat. Truck almost felt like it was skipping or hopping. At lower speeds when you go over “normal” bumps, it feels a little rough. I would have thought the air ride would have softened it a little. Anyway, anyone have any similar issues at highway speed or anything with this year/model/suspension to be concerned about? DCD21484-C564-4705-97B2-E8E0550A1D9B.jpeg
co-pilot
houston,tx
Hey!....sorry I don't have an answer for you, but "welcome to the forum ".....and nice looking truck!!!
Someone will probably chime in soon.....I've heard others with same problem...
P
pghguy1989
Greensburg, PA
Thanks...on both counts! It goes back to the dealer Friday, but we know how reputable dealers are. Wondering if it's a strut issue. Hope to have some ammo when I go back.
Nystagmus
NE Arkansas
2015 Longhorn CC
I may be wrong here….but the side profile pic looks like your truck has more rake to it than what I was expect to see with air suspension.
Burla
2010 Hemi Reg Cab 4x4
Driveshaft.
rule18
Admin
Administrator
NY
2017 Rebel
My 2017 has the four corner air as well. It does smooth out the ride a little bit. Out of curiosity have you started small, like is your tire pressure overly high? Otherwise, the previous posts cover some of the likely offenders.
Rlaf75
East Hartford CT
Could be a universal joint or a wheel balance issue. A universal joint vibration has the tendency to go away or become much less if you let off the gas. A tire vibration will start at any given speed and will normally stay if you let off the gas until it falls under that certain speed it started at.
Livinalittle
Ontario
2013 Sport, 6 speed, 4x4, 3.92
Usually, when my truck vibrates/shakes at highway speed (which is somewhat often) It's caused by dirt build-up in the rims; typically from driving on country roads after some rainfall. I would recommend starting there since it doesn't cost anything. While you have the wheels off, have a look and see if you lost a wheel weight or if you have a broken belt/tire out of round.
I'm not ruling out suspension or driveshaft, but from my personal experience, I would start with wheels and tires.
RLJ10X
Southern Indiana
I don't think it should be up to you to have to figure out what is wrong.
Knowledge is power, I get that.
You paid good money. You deserve a good buying experience.
Good luck. Let us know.
P
pghguy1989
Greensburg, PA
Just the slope on my driveway. LOL. Plus, I think I had it in entry/exit mode.
P
pghguy1989
Greensburg, PA
Yup. Dealer had it at 40. Took it home, chalk test down to 32psi.
P
pghguy1989
Greensburg, PA
Definitely not that. Haven't taken it anywhere yet and had just power washed it. Wheels are looking solid with no obvious bulges either.Thinking (hopin) just balance issue with tires.
