Right headlight is flaky? Percussive maintenance works...
carrottop
Washington
Having the similar problem currently with the driver side light. Removed it from the truck and works fine, remount and continues working for a couple days. Bought new harness with bulb connectors just in case any of them may be burning out. Considering a return and just cutting out the connectors completely and hard wire from the light directly to the chassis harness.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I think that it is a pigtail in the housing ??
There is a video that i recall watching a couple of times
The website belongs to the Motorcity Mechanic, he knows Rams
watch how he uses the Trim Tool on the dust cover fasteners, he lifts both the cover & the pin together
this was a follow up video that was made a little over a year later
Wahrsuul
Central S.C.
Its been almost 5 years now and no issues with mine after just twisting the flat blade connectors slightly. I even swapped out headlights and went to LEDs for a while before going back to the halogens. No issues with the connectors since.
