Right turns
Bridger hill
2012 ram 1500 with hemi, when I turn sharply right while moving engine slows and a red squiggly icon appears in instrument cluster,any thoughts
jws123
nj
Check your battery terminals and connections.
did you run codes? red squiggly icon I cant say I know what that is? its not yellow?
turkeybird56
Central Texas
Either look up the "warning light" in yer manual so we know what it is or take a pic and post, so we have some clue what is the issue. Definitely run a code check and see if any codes posted also.
You can turn off ESP for real, look up that procedure. Mind you I do believe this shuts off abs which you may not want to do, but for diagnosing reasons you can shut off ESP and see if this continues.
sounds like the stability control is kicking in, may have a wheel speed sensor or steering angle detection issue.
You have to look it up in the owners manual but I think holding the traction control button down for like ten seconds disables the ESC below 40mph.
