Right Wheel Bearing
bassslayer25
East, Kansas
5.9 360 V8
So if my right wheel bearing needs replaced will it make any sort of noise while driving? When im going it sounds like a scratching type of sound but when I press on the brake it quits. I know I need my right wheel bearing replaced cause my mechanic told me but this noise started a couple weeks ago and I just wanted to see if it was because of the bearing or maybe another problem came up.
tommyboi87
houma louisiana
5.2 Magnum
It's could be your bearing, but make sure there isn't anything on your brake pads.
Sent from my SAMSUNG-SM-G925A using Tapatalk
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
Alright, never know. U joints can make a scratching noise too, just suggestion.
ramburger
if yer mechanic said do the wheel bearing then dont put it off :crazy:
also the scratching could be/have been bent brake shield
bassslayer25
bassslayer25
East, Kansas
5.9 360 V8
Man I never thought about the break shield! lol Thats honestly probably what it is. And yeah I need to get that RWB fixed lol
Lethalweapon100
NY
V8 5.9 Magnum
Shake down the front end, specifically the right wheel. Pull the wheel off and take a good look at everything. For me, there was a little metal tab on the brake pad that had been rubbing on the rotor and making noise.
Sent from my SM-G920P using Tapatalk
Ram digger
Medicine Hat AB
5.2 magnum
Most likely the inside of the bearing starting to go, mine just gave out yesterday no lie lol, so don't put it off any longer or you'll be on the side of the road with mad camber like I was or risk breaking more components.... Lucky I pulled over right away, otherwise I would have wore the **** out of my rotor and calliper. Funny thing was, I was on my way to get a wheel bearing.....
