rims input
cummins21
TEXAS
v6 3.9
i am wanting to get some kinda new rims for my truck. i really like the rock stars rims. but i cant seem to find any that would fit my truck. do they make them for a 2001 1500.
MADDOG
Living in a Firepit
I believe your wheels/hubs are 8-lug so you need to find wheels that fit the specs below:
1994-2002 2500 2WD/4WD Steel Wheels:
Bolt Pattern - 8 on 6.5", 9/16" bolt
Wheel Size - 16" x 6.5"
Offset - 4.75"
2000-2002 2500 2WD/4WD Forged Aluminum Wheels:
Lug Pattern - 8 on 6.5", 9/16" bolt
Rim Size - 16x8"
Offset - 6.25"
Offset will change depending on how much wider you go over the stock width dimension.
Torque Spec: 120-150 ft lbs (163-203 NM) on 8 stud single wheels
ramhunter9
P-Star Jeep Wrangler
He traded in the CTD for a 1500 .
Needs to update his info
MADDOG
Living in a Firepit
aha! Well, I gots specs for that, too!
2000-2003 1500 2WD/4WD 17" Aluminum Wheels:
• Lug Pattern: 5 on 5 1/2
• Weight: 23.5 pounds
• Rim Size: 17x8"
• Actual width edge to edge: 9 1/16"
• Backspacing: 5 9/16".
• The space from the outside edge to the mounting surface (against the rotor) is 3 1/2".
