Hey there--
Have you gotten this looked at by a dealer yet? We'd like to look into this to see what we can do for you. Please send us a private message so we can gather more information!
Courtney
Ram Cares
Not Yet; I reached out to the principal owner to a location near me and haven't heard a response for a week. I did some research of my own and I am concluding with evidence that FCA send me the recall USB CSN VB3 which was done awhile ago. I reviewed the log file last night and found strange evidence that has me wondering if they sent me the wrong file to begin with. As you can see below the software log beginning is from the VB3 USB (Date Mod 11/09/2019 3:27am)
********SOFTWARE UPDATE LOG********
Starting Update
Total units to update: 15
Installing unit 3 SYSTEM CHECK
Got the unit installer for SYSTEM CHECK
System Market matches
System Product matches
system_module_check: Part_number 68190260
System Model Year matches
Installing unit 4 IOC-BOOTLOADER
Got the unit installer for IOC-BOOTLOADER
variant_product=VP4, variant_modelyear=MY18, v850Type=hs, v850Stub=stub
bootloaderUpdater /mnt/primary.iso.36882.4644/usr/share/V850/hs/cmciocblu.bin
bluStub /mnt/primary.iso.36882.4644/usr/share/V850/hs/stub/cmciocblu_stub.bin
bluStubLong /mnt/primary.iso.36882.4644/usr/share/V850/hs/stub/cmciocblu_stub_long.bin
bootloader /mnt/primary.iso.36882.4644/usr/share/V850/hs/cmciocbl.bin
blStub /mnt/primary.iso.36882.4644/usr/share/V850/hs/stub/cmciocbl_stub.bin
manifest_file /mnt/primary.iso.36882.4644/usr/share/V850/hs/manifest.xml
dev-ipc operation start
target bolo version 17.9.0
bolo version on stick 17.09.00
Bootloader is the same version
No Bootloader Update is needed
Installing unit 5 IOC
v850bin /mnt/primary.iso.36882.4644/usr/share/V850/hs/cmcioc.bin
v850binStub /mnt/primary.iso.36882.4644/usr/share/V850/hs/stub/cmcioc_stub.bin
*** As you can see above it states I have 2018 which is incorrect; and part number is different than behind the radio. You will also see on comparing the v850Type=hs on this one as the next one I will provide below.
This Software Log I am going to provide below is the one that has put the head unit into a boot loop. Firmware was provided by u connect website via Vin# search tool. Downloaded many times with firewall and antivirus off; used 7 different kinds of USB drives that have been formatted FAT32 - not quick format feature; used 7zip to extract files to USB drives. Some USB drives are generic and some are 16gb & 32 Kingston brand name. Now in the log notice that the part number is correct; model year is correct but V850Type is TB Not sure if it is correct.
Starting Update
system_module_check: Part_number 68224525
variant_product=VP4, variant_modelyear=MY14, v850Type=TB, v850Stub=stub
bootloaderUpdater /mnt/primary.iso.36882.4644/usr/share/V850/TB/cmciocblu.bin
bluStub /mnt/primary.iso.36882.4644/usr/share/V850/TB/stub/cmciocblu_stub.bin
bluStubLong /mnt/primary.iso.36882.4644/usr/share/V850/TB/stub/cmciocblu_stub_long.bin
bootloader /mnt/primary.iso.36882.4644/usr/share/V850/TB/cmciocbl.bin
blStub /mnt/primary.iso.36882.4644/usr/share/V850/TB/stub/cmciocbl_stub.bin
manifest_file /mnt/primary.iso.36882.4644/usr/share/V850/TB/manifest.xml
v850bin /mnt/primary.iso.36882.4644/usr/share/V850/TB/cmcioc.bin
v850binStub /mnt/primary.iso.36882.4644/usr/share/V850/TB/stub/cmcioc_stub.bin
Have you ever seen anything like this before?
