rotors
the codes
Houston, Tx
Magnum 5.2
How many miles would you guys say you get out of oem/stock rotors? Im not sure if my dad ever had them replaced before he gave me the truck, but I feel like my brake performance is lacking, and we just put new pads on about 10,000 miles ago, so im thinking maybe its time for a rotor replacement..let me know what yall think
txbass06
NE Texas
5.9 Magnum
Mine had 89k on them when I replaced them but still had plenty of meat left on them
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Still on OEM rotors as far as I know. 148k They may have been changed long ago by the previous owner.
the codes
the codes
Houston, Tx
Magnum 5.2
hmm I'm at 162,000 and I'm pretty sure they are the originals
Tapatalk Addict
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
The rotors aren't gonna affect performance unless they are severely warped and you'll feel the steering wheel shaking while braking. What you'll probably need to do is change out your brake fluid as Michael has suggested. Brake fluid is hydroscopic which means it attracts water and will cause the brake lines to rust from the inside out as well as cause bad braking.
the codes
the codes
Houston, Tx
Magnum 5.2
thanks for the info and link, thats some very helpful info
Hotroder383
Washington Mo
318 or 5.2 which ever you want
Rotors have a min thickness and the only way to tell is to mic them. Good brake job you mic them and check run out or "wobble". How long they last depends on what pads you run too. If you use stock pads they last awhile if you upgrade to ceramic or performance pads that are "harder" then you wear the rotor out faster. Personally I replace or turn my rotors every time I do a brake job, but I use ceramic pads. Also most deff replace the fluid if it is dark looking, as said above it will go bad just like any other fluid it needs changing every so very often.
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
I had 94k when I changed my front rotors. Back are still oem but I use Kevlar rear pad don't know if that has anything to do with it. BTW boy do those Kevlar pads really work good especially when towing. I would venture to say best pads I have had.
stevenmicheal
