Dinky
Well, in the 4 and the 6 pictures there is that part that is attach to the radiator that one long air dam I will call it is only hold on with 4 bolts and three push pins, two bolts on each sides if you take that off you will be more able to get in there and put those bracket on..
You see on the 3rd picture that one part is not there because you have to trim part of the rubber anyway and even at that I had to drill a 1/2 hole in the hard plastic so I can tighten the one bolt down to hold the bracket. So you see that the 3rd pictures I had to take it off completely so I could put the bolt on.
And then I thought about it, I said that I really didn't have to take the air dam off because the air dam really wasn't in the way it was the part that was attach to the radiator, it was some kind of air dam to direct more air into the radiator. Once you get under there you will see what I'm talking about.
I know exactly what your talking about. i will keep that in mind when i install mind thanks for the info. i have another set light i want to install at the gap between the bumper and grill. figured i will be installing all at once so still waiting on my light bar lol.
