Rounded off lug nuts
Arlucian
Port Angeles, WA
What do you guys reccomend? Went to take my wheel off today to fix my hub and 3 of 5 of the lug nuts are rounded.
dapepper9
Iowa/Nebraska Border
5.9L V8
Id say get one them sockets made to grab rounded bolts with a breaker bar. Then replace. Also use a penetrating oil top put less stress on it
Arlucian
Arlucian
Port Angeles, WA
Well id do that bit in my oppinion drill bits are cheaper i decided to drill them out its a ******* pain but im getting there slowly but surely. Seeing as im getting new studs with the hub i decided this was the most cost effective option, and yes pb blaster is in the box i keep in my truck, i literally dont leave home without it. Although i dont do much home leaving lately anyways. I really didnt want to do that but i got laid off today so i'm going home and the sooner the better.
newrammer
5.9 v8 magnum
Break out the drill and blowtorch! Seriously though I've done it with a drill before on my old truck but what peppy said makes it sooooo much easier.
jwheeler
Washington
Get yourself a set of the proper sockets to remove them and it will only take a few min. How do you do it with a drill? Just go at em until there is nothing left?
Arlucian
Arlucian
Port Angeles, WA
Just completely remove the stud via drill takes forever but i'll go through 3 drill bits or so doing this so itll cost me less than 10 bucks and more of my time. Look up i don't have a job anymore so ive got to split pennies. Set of those sockets would run 45 bucks or so.
dapepper9
5.9L V8
I got a set that'll run up to 19mm for $12 at Oreillys. Decent set too.
Sorry to hear about that tho.
loki223
Spokane, WA
Cummins 6.7
The other ways of doing it for cheap as pounding on a socket that's just barely to small and forcing it on. But your sacrificing that socket and lug nut in the process. Or if you have access to a welder, weld something to the lug but that will allow you to take the nut off. But not everyone has a welder in their garage
Merc225hp
NA
truck
gas
As posted get a smaller mm socket, just need one not a full set. One socket will do the job just fine on need for three, you will have to pound the nut out of the socket mind you and thats not hard at all.
Arlucian
Arlucian
Port Angeles, WA
Got em off but stuck here again till monday i want to be gone right now but here i am.
