Rpm's @ highway speed
tim johnson
Gallatin, TN
07 Ram 1500 5.7
Without knowing the rear end ratio I know this will be an open ended question but here goes...
At 70 mph how many rpm should I be turning? It stays around 2200. Just curious, on my 04 with the 4.7 at 70 mph it is lower. Just wondering if maybe the convertor is not going into lock up.
BTW, is there a tag or sticker somewhere that will tell me the gear ratio of the differential?
Thanks!
Burntfire
If MDS is engaged it will make the RPM's slightly higher.
glass3222
Central PA
you should have a tag in the glove box or on the rear axle that tells you the gear ratio.
truckin151
2013 sport
With a 4.56 rear gear @70mph mine is turning right around 2300rpm
With the stock 3.92's @70mph it was right around 2100rpm
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
3.92 with a 31" tall tire at 70mph is 2082. ( AOD calculated)
Yours have a 5 speed? If so, could be 3.55, with 5 speed 2155rpms. ( with 5 speed)
truckin151
2013 sport
That's taking both OD gears into consideration right? 3.55s would give it a lower rpm than a 3.92 or 4.56. 2155 @ 70mph is about where mine is at with a 4.56 Rear gear.
Graygoose
Oklahoma
Convert, for now.
small
sorry, corrected my post above
truckin151
2013 sport
Yes, with OD engaged on both.
99% positives that is incorrect then, a 3.55 rear gear will give you a lower rpm @70mph than a 3.92 and definitely lower than a 4.56 rear gear. Check your math again
tim johnson
tim johnson
Gallatin, TN
Do you have Tow/Haul on when going 70mph?
Negative, Ghost Rider.
To me it feels like it is not going into the 2nd OD but I could be wrong. I have been driving an 04 with a 4.7 for the last 6 years.
