Jhuss96
- Apr 17, 2019
- 199
- 140
- Location
- Northeast US
- 2016
- 5.7 Hemi
Did you look carefully at all 6 brackets to see if they are all the same? Quite often Ram boards have a different bracket for front drivers. One reason..because the front drivers bears the most weight most often & maybe because of that impacting bracing as well?
Sent from my SM-N960W using Tapatalk
I see your brackets require assembly.... what do they look like assembled because could it be possible that you were just holding the part of the bracket that bolts to the rocker, up there in its place wrong?
What year is your truck and what is the part number for your kit?
the impact brace was added for the 2016 model year. I do remember guys running into this problem back then but the running boards didn't list compatable for '16 and dealers assumed they would fit.The part number is: 82211700AE and my truck is a 2016 1500 Sport Quad Cab.
The only other thought I have is it may be a running board made before they produced trucks with the impact brace? The mounts look different and I purchased off ebay rather than a dealer so it could be an old production. Either way I got it for a good enough price that I'll figure out a way to make it work right.
That’s weird, when I searched that part number, this came up which looks just like the brackets did on mine. What does your brackets look like assembled?
https://www.bamwholesaleparts.com/oem-parts/mopar-black-aluminum-running-boards-quad-cab-82211700ae
Yeah, those are much different brackets because those don’t even have the spot for the two smaller bolts that attach the bracket also to the pinch weld on the very bottom. But can you not flip that upper flange part over where it bolts to the cab? It would seem to me that the triangular shape part of that would be the top....
I see that now, that what I suggested probably wouldn’t work but maybe you need to go look for the right brackets like at a junkyard somewhere because those that you have just do not seem like the right brackets for your model-year pickup. If finding the right brackets that look like the ones I posted in the pictures is out of the question, then you’re just going to have to get creative with a plasma cutter, cutting torch or cut off wheel to trim those two front brackets and then repaint them before you attach them to your truck.
But see then again, I don’t see anywhere on those brackets that you have that allows the bracket to also be attached via two small bolts right there on the very bottom of your rocker panel where the pinch weld is. Those pictures that I supplied don’t really show it, and if I would’ve thought about it I would’ve included that in the picture I took of my new running boards but there’s actually a total of four bolts that attach each bracket to your cab. Just the two big bolts that are visible in the picture I took are not the only two bolts.
These do not seem to utilize those two smaller body holes you're referencing, my old running boards did not utilize those either but I do see that the newer mounts utilize them. I'm going to see if I can purchase the newer mounting brackets because the boards themselves appear to be exactly the same between years. If not I'll get creative with that one flange. I got the set new for less than half the cost for a brand new set, so I really can't complain if I have to pay a little to get it all fitted right.
OK so, help me clear some things up… In the picture below.....
....you’ve only got two of those kinds of flanges. Since those are a lot flatter on top, is it possible that those two flat plates above is what gets used on the front of your running-boards?
I would think the reason why the other four, that are exactly alike- like the one attached to the bracket in the picture below....
....is why you’ve got four of those to go in the center of and on the back end of your running-boards, is because there’s no clearance issues like where the front brackets go. And since that’s obviously an older design, maybe that’s how that kit was designed before they designed the kit like what I’ve got where all the brackets are virtually the same and won’t have clearance issues with that cab bracket that you have to deal with.
But just on a sidenote, in the picture below where those two arrows are pointing is where the extra tab I’m talking about should be that bolts to your pinch weld which I didn’t see on your new brackets; which doesn’t matter I guess, your runningboards should be secure enough without those, I would just think that maybe they added those in later on in the years just for added support.
My aftermarket running board brackets are exactly the same as the factory ones but they still bolt up exactly the same way as the OEM brackets with that little tab right there.
I have test fitted the square shaped flanges and it is unfortunately the same result, the brackets all are a bit too tall to sit flush against the impact brace. I have seen some people simply remove the brace, which I may end up doing depending on how much luck I have with other solutions. Unfortunately the IIHS crash tests between '15-'16 before and after the brace was introduced seems to have little if any impact on wheel protrusion & driver compartment deformation in small overlap crashes which the brace was designed to stop. So I don't think I would be putting myself at serious risk by removing it.
Absolutely agree with you about the bracket design though, it seems to be pretty clear these brackets were designed for 09-15 Rams before the brace was introduced. I did a bit of research before getting them but mostly based on the part # and I don't think theres any way I wouldve noticed such a subtle difference in mounting.
I see what you mean about the pinch weld mounts, I'm not too worried about those because my old set of boards were hard as a rock and didn't utilize those mounts.
What set of aftermarket boards are you running? I'll see if a company is willing to sell me one bracket like the one you posted above. There are tracks on the underside of my running boards that allow me to get creative with what mounts I use, so I may test a few out.
