Running lights only working on one side??
FancyStancy
Cummins 6.7
the running lights both front and rear are not working on my driver side. when I hit lock/unlock the lights come on, but when I flip the switch in the cab to the running lights, only the passenger side comes on. I did some work to my batteries recently. I noticed a spark when putting a terminal on. I know you are supposed to remove negative terminal first to avoid shorts but it doesn't seem to work with the parallel battery system. anyways, would it be possible for it to have blown the fuses for the running lights on one side?? any other suggestions?
