Rust problem coild spring buckets
bdemutis
5.9l 360 gas
Rust problem coil spring buckets
So my front lower spring mounts are really bad the buckets are probably on there last leg. Is there anywhere I can buy buckets for the front axle?
Merc225hp
NA
truck
gas
No sir you can not buy a factory replacement spring bucket. You might be able to get them cut off an old front diff and and have them welded to your diff. There are aftermarket spring mounts out there but these are more meant for custom building. One last opt is to just find a replacement front diff and just swap them out.
B
bdemutis
5.9l 360 gas
Well where can I find custom ones I'm not spending $200 on them. Ill just fab them myself if I have too.
B
bdemutis
5.9l 360 gas
If I cant find them for a good price I might use 1/8" steel plate and a plasma cutter and cut circles the same size as my springs then I will make some tabs on the side to hold the coil in place. I already drew some ghetto pictures and a sketch.
Merc225hp
NA
truck
gas
Dodge RAM Replacement Coil Buckets | eBay
I currently sell Coil bucket replacements on ebay. You can click the above link to view pictures. Im not sure if you will be able to find anything for less than $200
Nice now we have a place to direct people that need them. Ok you are making this part what about the cab mount on the body side they are NLA not to be found anywhere.
Johnn123
Ontario
Very nice! This will be a very link to give people who need new ones! As Merc asked, do you guys make body cab mounts? They would be very useful to have!
