Rust spots....
PinkCamoDodge
Out in the Boondocks!
Magnum v8 5.9
So I have only two rust spots on my truck. I want to see if I can take care of them myself. They aren't holes, but rather superficial I guess you'd say, but I do not want them spreading. What would be a good way I can fix them myself? Sand them down real well? One is about the size of a quarter., the other area is even smaller. Thanks for any input.
WOOPS! This was supposed to be in the 2nd generation section. Dunno how I made it here, I apologize mods!
GotExhaust.com
WhiteExpress
Midland, TX
I'm concerned as to where the rust spots are.
If its on the door bottoms or wheel wells, it's very likely the rust is coming through from the backside, and is not as 'small' as you may think. :-(
Be prepared to be opening another can of worms.
2K10HemiRam
Hometown: Tacoma, WA Stationed: Alamogordo NM
Whats the locations of the rust spots? that would aid in someone being able to chime in with the best help for your problem, maybe even pictures of the spots? If it's on the body than the simple light sanding, priming, painting, and clearing should do the trick. I would hope that it'd be a cheap repair for a shop to do also.
Nice truck btw, reminds me of my 99 which was the same color and going down the same black/white yours is.
TDWS90
NAS Lemoore, CA
I have a similar issue, instead of painting it could I use rhinoliner or something similar? its the panels below the doors.
PinkCamoDodge
PinkCamoDodge
Magnum v8 5.9
I will get pics tomorrow.
One is on my passenger door, about 4 inches below where my sideview mirror is. (She was hit by a bb gun on accident, and the bb is what started the spot :/ )
The other is on the right front fender right where it meets the bumper.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
You live in LA?
Unless you live on the coast, you just need to sand and paint them.
PinkCamoDodge
PinkCamoDodge
Magnum v8 5.9
We're right on the LA/MS line.
I circled the two spots on this pic, though they're pretty hard to see in this pic.....
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Gotcha, but are you in an area where there is a salt water problem?
If not, you don't really have a lot to worry about in that it will only be surface rust. You just have to catch it before it starts peeling paint.
PinkCamoDodge
PinkCamoDodge
Magnum v8 5.9
Not really no. Yeah the paint is flaking off right around the bigger spot on the door. :( Didn't want the paint to keep chipping.
Ramboy86
5.9L Magnum V8
I just recently purchased my first Ram. 1996 1500, 5.9L Lifted 2 inches. Beautiful truck, but I noticed it has some rust in a particular spot that Im skeptical about.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Ramboy86
5.9L Magnum V8
Sorry for the image size. I just wanted to know how bad this is for a Ram with 200,000 miles on it. and if anyone had repaired something like this
Merc225hp
NA
truck
gas
Well what to say.
Some of it is not bad, sand, prime, paint with POR-15.
Rockers are available so those are easy to get.
Ok now for the bad news, the front body mounts are toast and guess what no one makes a replacement part. You will have to build your own or find a cab with a good one to weld under your truck.
If someone does know where to get them PLEASE post up the info as to where to get one, as I am down to looking for a used cab to get one from. Many a web site say they have them but when contacted nope NLA.
Ramboy86
5.9L Magnum V8
Thanks for the info. Ive been looking around and I guess the only fix is to have it fabricated or to cut out a good one from a doner truck and weld it.
stevenmicheal
