Rusted out Fuel pump lock ring and Tabs on tank! 2004 1500 SLT Quad Cab
ncdodgeman
4.7 V8
Dropped the tank to replace the Fuel pump…. Original lasted 180k miles! Got scared when I noticed all the locking tabs rusted away along with the locking ring. Found a product made in Michigan by a company called Gas Tank Renu. It’s their TR-26-R kit it replaces the standard ring with one you put self tappers into the plastic part of the tank! Looking forward to see how it works! Beats paying $700 plus for a new tank!
Jmlp320
Rhode Island
How did the kit work out? I’m dealing with the same problem and can’t find a tank anywhere
Jmlp320
Rhode Island
Awesome mine should be here on Saturday, any recommendations on install or are the directions on point?
N
ncdodgeman
4.7 V8
The directions are pretty straightforward you will just have to cut off any remaining parts of the old ring retainers…. My suggestion go ahead and empty out the tank and clean it up after you remove the old ring retainers while you wait
N
ncdodgeman
4.7 V8
It’s basically a round ring you screw into the plastic with self tappers over the fuel pump it comes with a tube of sealant to put on the screw to make them airtight…. Glad I could direct you to this money saver!
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
you can find the part online
GM - DODGE- FORD PLASTIC GAS TANK LOCK RING REPAIR #TR26-R​
FIXES RUSTED OUT TABS ON GM PLASTIC TANKS
The OEM Rings are getting almost as hard to find as Hens Teeth
Rfammo
Virginia
This kit was the ticket! Worked exactly as advertised. Thanks for the tip.
mmcquinn
