SD for uconnect
Tx2015Ram
What sd card is everybody using for the uconnect. I have tried several smaller gig cards I have that work just fine, but when I use my micro 64 g with adapter it won't read it. Is it due to the adapter or maybe the wrong type of card. I don't mind buying one, would like to upgrade to a 128 g but money isn't endless for me. So what are y'all using 64 g or bigger that works?
Sent from my SAMSUNG-SM-G920A using Tapatalk
ColdCase
What format were you using? Micro SD with adapters are much more troublesome than SDs, and usually slower. Did you have 64G of music files on it as it can take quite a long time for the radio to index the files, during which time it looks like the card is not readable.
I've only gone up to 64GB. I think any SD card would work, but you may not get full capacity.
T
Tx2015Ram
I only loaded a few songs on to try it. I tried a smaller gig micro and it worked so must be the type, it's an sdxc, not sdhc or whatever. It will only let me format to exfat, not fat32. So before I run out and buy one that might not work, just wondering what works.
stevenmicheal
