Seat bolt torque specs
quietpeen
2021 TRX
Hellcat
Does anybody know what the bolts for all seats are supposed to be torqued to?
quietpeen
quietpeen
2021 TRX
Hellcat
Wow, i would have though it would be a lot more than that.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Mine had red locktite on the floor bolts. They felt a lot tighter that 30 pounds getting them out. I ran a tap through holes and the bolts through a die before putting them back in and used antisieze on them. I know you're not supposed to re-use them, but heck with that.
quietpeen
quietpeen
2021 TRX
Hellcat
I’m definitely reusing them but I was planning on putting blue loc-tite on them rather than antiseeze
quietpeen
quietpeen
2021 TRX
Hellcat
30 for the rear and 21 for the front ones
So I just saw this again on a cummins site about a 4th gen truck, And that is for the front seats. When taking the bolts out it seems a lot more than that but that could be because of the red loc-tite that they put on them. It then said 63 for the rear seats. Wonder why there are so much more.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
On my truck a couple were rusty underneath so I wanted something coating the threads. I had to use a breaker bar to get three of mine out between the loctite and rust.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
Torque specs are normally assigned by thread pitch, size, and grade of fastener. Here's a link that may help some folks: https://www.portlandbolt.com/technical/bolt-torque-chart/
It's important to note that bolts aren't torqued based on how much force it takes to remove them...So something that goes in at 30ft/lb with red locktite might be 100ft/lbs coming out with no heat to break it. Lots of comments about how tough things are to get apart, but that matters not to the OP's question.
