Seat Senors
bchap05
Anyone know if the seat sensors that are tied to the seatbelt are the same as the airbag? I'm assuming they are since they are weight based.
I dont think mine are correctly detecting weight. My Fiance can sit in my passenger seat with no seatbelt and it won't beep unless she sort of wiggles around and can trigger it.
This would be fine as the seat belt sensor is annoying but I assume its the same one for airbags so I need to get it checked.
Truck is a 17 with 2500 miles. Only issue is it doesn't seem to always do it so I'm sure when I get to the dealer the sensor will work fine. Especially when some 200lb+ dude gets in to test it.
guarj17
Long Island, NY
I actually just posted something like this in the "things you don't like about your ram" thread. Does it cause the sporadic blinking errors on the cluster like mine?
B
bchap05
It will make the noise and pop up passenger seat belt unbuckled on the screen. Which is what it should do if someone is in the seat without their belt on. But it is not consistent as she can move in the seat and purposely make it go on or off by slightly shifting her weight.
If she is wearing her seatbelt it doesn't do it. But I'm concerned with it since it is a weight based sensor its probably turning off the air bag too as it thinks someone too light is in the seat.
RubberFrog
It could be worse. Your GF could be some big heffer blowing out the passenger side tires.
B
bchap05
Hahah if she was a heffer I'd leave her on the side of the road to solve the problem
00R/T
CT
The RAM doesn't disable the airbag if there's nobody in the passenger seat. The occupancy sensor is used only for the seatbelt light. It also isn't weight based - it's supposed to determine if the occupant is static (stack of books) or dynamic (person). It might just be the way she sits. Either way, I wouldn't worry about it.
B
bchap05
Sweet good info thanks.
guarj17
Long Island, NY
From my other post:
"1. Seatbelt sensors. If me and the girlfriend are in the truck, and we hit a bump, or any change of weight on the seats, the seatbelt notification on my screen spazzes out and flickers back and forth between Driver/Passenger seatbelt unbuckled. It does not seem normal the way it spazzes at different rates of speed."
For me, it's not that I worry about it, it's just hella annoying flickering all over my dash whenever I'm on uneven road or either me or her move. Anyway to fix it? It's going in to the dealer the end of next week, but in the past, I've noticed that anything that goes to the dealer, comes out exactly the same. Lol.
00R/T
CT
From my other post:
I assume you have the seatbelts fastened when that happens? That's definitely not just a load detection issue. It sounds like you have something legitimately wrong.
