Second battery
MikeG
Livonia La.
Anyone running a second or upgraded battery ?
If so which one ? Or should I just go ahead and put 3 batteries on the frame rail?
Mechman 300 amp alt.
All Rockford fosgate
6.5 components front
6x9 rears
4 in dash
Prime 400.4 on doors
Prime 150.2 on dash
2 prime 500.1 on subs
2 P2-12
XS big 3
XS 0 awg to power block
XS 0 awg from ground block to frame
XS 4 awg to all amps
audio1der
Airdrie, Alberta
Nice setup; that'll sound clean as hell. I can't comment on the 2nd batt, just love a nice, well thought-out setup.
MikeG
MikeG
Livonia La.
It does sound very well but this light dimming is bugging the hell out of me.
It did a 153.2 db and I think there's more left in it
baum
savage, mn
2015 Laramie
are you doing one 4 ga run for all 3 amps? if so that should be a 0 ga run.
i havent looked, but where do they put them in the heavy dutys? i know in the older GM the spot was still there so i would utilize it when i could.
dont forget to get a battery isolator also.
MikeG
MikeG
Livonia La.
I have 0 awg from battery to distribution block.
4 awg from distribution block to amps
Etroze86
Grand Forks ND
What are you running as a main battery? and you really shouldn't have any kind of dimming with that mechman as I ran same power if not a little more on all stock electrical with no dimming. I would double check your grounds first and then spend money later.
N1ck
Regina Sk
I would look into the Northstar NSB AGM94R for a replacement battery (if you go that route). I'm in the battery business, very high quality batteries.
MikeG
MikeG
Livonia La.
In running a replacement yellow top
MikeG
MikeG
Livonia La.
The dimming isn't bad. It's more of a slight flicker but its enough to **** me off after the cash I've spent.
I'll check all ground this weekend and probably going to replace all factory grounds with 4 awg since I've got about 15' left over
Etroze86
Grand Forks ND
That's a great idea, I would also get rid of that yellow top, I sell auto parts and that battery is literally the most returned item in the store because they don't last like they used too.
N1ck
Regina Sk
Is it as good as a XS d4800 ?
The D4800 is a 48BCI group, physically it is smaller than our oem battery and will not fit the tray the same.
I do believe XS Power is manufactured by Northstar with Telecom posts, for whatever reason :crazy:
General rule of thumb with batteries, the heavier the battery is, the better it is. the NSB-AGM94R is 5% heavier than that XS D4800.
NSB_AGM 94R - 1,650 Cranks for 5 seconds, 860CCA after / 159 Minutes Reserve. 70Ah
XS D4800 - 815CCA / 120 Minutes Reserve. 60Ah
For arguments sake.
Optima 34/78 Yellow Top - 750CCA / 120 Minutes Reserve. 55Ah
I would definitely look into the Northstar, this battery will be huge in a few years. It is sold as a oe option in lots of fleet vehicles, buses, etc.
charonblk07
Calgary, Ab
F1-A forged 349ci
The second battery will help run the system longer but unless you are running an independent battery with a low peak time it won't help your issue. I would recommend installing a second battery like an XS4800 which have very low draw times so there should be less voltage drop from the battery on sudden bass hits. It really shouldn't be an issue since you're running the Mechman but isolating your audio from the car battery should help eliminate the problem if you have an isolator installed.
I'm running dual yellow tops, I know they're not the best battery but they sure do the job for me.
MikeG
MikeG
Livonia La.
Problem solved.
Went to leave work at lunch time and truck cranked over slower than normal. Went got the battery tested and it failed after 4-1/2 months. They replaced it under warranty and all is good now. No light flicker and subs sound a little more crisper.
I'm going do another clamp test on my amps to see if the voltage has changed
I'll be ordering three XS tomorrow and the aluminum to fab bus bars.
Thanks for yiur comments and suggestions
Boulevardvette
With a Mechman 300 you should be good way over what you are running. Just wondering why you are ordering three more batteries? You going to upgrade?
MikeG
MikeG
Livonia La.
I want to isolate the sound from the starting system.
One will be for starting and the other two will be for the amps.
I will be upgrading to t2500-1 next year
shaunnz
